Search Forums | Classifieds (144) | Skins | Language
Skunk in live trap.
gene_champ
Posted 10/18/2020 08:24 (#8551290)
Subject: Skunk in live trap.
NC Iowa
I was catching possums in the barn. Got a skunk today. If I let him set a day or two, will be be less likely to spray. Not in a handy place to cover with a blanket. I didn't want to mess with him before church. Not very bad when I get back either.
farmwithjunkrrv
Posted 10/18/2020 08:42 (#8551324 - in reply to #8551290)
Subject: RE: Skunk in live trap.
South west of Winnipeg MB
How small is the trap? If it can't lift it's tail it can't spray.
born_in_ad1
Posted 10/18/2020 09:04 (#8551376 - in reply to #8551290)
ESW ND
It'll spray just as easy even if it was in there a week. Cover with blanket, expect to get sprayed. lol
Bruce NW Ia
Posted 10/18/2020 09:09 (#8551389 - in reply to #8551376)
Cherokee County, Northwest Iowa
Cover him with a blanket, sing him a song to keep him calm (no lie, that is what my neighbor said to do, but then again, my neighbor jerks my chain occasionally), you won't get sprayed. I am three for three, safely, but have also decided to quit while ahead. Good Luck. bruce
Chief Illiniwek
Posted 10/18/2020 09:11 (#8551395 - in reply to #8551389)
West central IL
I’m 2 for 2. Be calm. I generally have someone stand on the far end of the trap being a bit more animated. Have a 4x4 ready. Lift the trap door just enough to get the 4x4 under it to wedge it open, and run like hell!
born_in_ad1
Posted 10/18/2020 09:18 (#8551415 - in reply to #8551389)
ESW ND
Hidden cameras could come in soooo handy sometimes. lol
Bruce NW Ia - 10/18/2020 09:09
JRthefarmer
Posted 10/18/2020 09:16 (#8551408 - in reply to #8551290)
SESD
boys caught a double skunk surprise this week. They ended up popping them with the .22. The trap was outside though, and away from the yard.
tack
Posted 10/18/2020 09:26 (#8551431 - in reply to #8551290)
Central Arkansas
Hope you have a rope tied to the trap, but it can be done after covering trap with plastic or tarp. Then, after church, baptize the skunk while in the trap. Use the rope to retrieve trap after 30 minutes.
AR Plowboy
Posted 10/18/2020 09:41 (#8551464 - in reply to #8551431)
East Central Arkansas
I have caught several around our Baptist church. I have used the road ditch when caught after a large rain but the ceremony has been performed in the trash can a few times. It might be interesting to watch some from other denominations sprinkling though. Had one get it's head caught in a small hole in the base of the central air unit. There wasn't a safe way to dispatch with a gun. I am sure I had a strong odor following me around after that.
notillmc
Posted 10/18/2020 09:42 (#8551467 - in reply to #8551431)
SW TX PANHANDLE
I’ve had 3 take up residence on my back porch just this week. Have found that a water hose is pretty effective in getting them to leave. So far it has worked on all three, haven’t got sprayed yet. Apparently they’ve been sharing food with the dog. The dog absolutely lives them alone and skunks will walk right by the dog. Skunks won’t be back, got them far enough away from the house and they met their maker. Lots of skunks in the area right now, dead ones every few miles on highway.
PhilToddCo
Posted 10/19/2020 17:13 (#8553948 - in reply to #8551431)
Osakis,Mn
Your skunks must be able to hold their breath longer than mine,lol. Mine only last about 2 minutes under water.
Rusty6
Posted 10/18/2020 10:24 (#8551537 - in reply to #8551290)
S.E. Sask.
I remember catching a skunk in a live coon trap a few years back. With a lot of patience I was able to release the skunk to freedom with no harm done and no spray either. Maybe just lucky. We didn't have many skunks around at the time and I didn't want to kill it.
buck owens
Posted 10/18/2020 11:18 (#8551601 - in reply to #8551290)
provost, AB
It'll die eventually. I caught one yesterday in my pet friendly racoon trap.
Ken
Posted 10/18/2020 13:07 (#8551759 - in reply to #8551290)
central Ia
tried the blanket over the trap once it worked for about 100 ft but I got it away from the house, good luck or try an use the mini excavator to move the cage, least your farther away
Edited by Ken 10/18/2020 15:08
PeteMN
Posted 10/18/2020 13:14 (#8551764 - in reply to #8551290)
E.Central MN
Sometimes they're more calm in the live trap when its getting close to dusk. I try to not agitate the skunk, just slowly get close enough to shoot it with the 22. But once you shoot it, you better be ready to grab the trap and take it to where you want to dump out the skunk because once its dead it will relax its muscles in minutes and will stink. I bait a live trap with some marshmallows. I used to use cat food, but would catch a cat once in a while.
School Of Hard Knock
Posted 10/18/2020 20:19 (#8552431 - in reply to #8551290)
Central ND
I've often wondered about putting trapped skunk to sleep by leaving a propane weed burner valve open up close to it and asphyxiating it.
But when it does die, I'm about sure it will lose muscle control and drain its scent glands anyway.
R.Boss
Posted 10/18/2020 21:12 (#8552610 - in reply to #8551290)
Leave a rope on it next time...I drag mine to the pond.
Buster 50
Posted 10/18/2020 22:19 (#8552785 - in reply to #8551290)
North West IA/western AZ
Lots of good hints. My experience was carry a tarp big enough to hide behind, drop over the trap and gently carry to where you want it. I had an open mowed spot that I set him down on, then opened the trap. I had to lift the car end of the trap for encouragement and he finally came out. He never did spray. Another was in a spot that I didn’t care if it smelled so I shot him with a 22. He did stink.
MNfarmer85
Posted 10/18/2020 23:16 (#8552841 - in reply to #8551290)
South Central MN
I've used an old tarp or piece of ag bag plastic, best is with a solid door trap and come from that end and gently cover it, they will let off a whiff of something but not full strength spray. Was able to pick up and move the trap to a 55 gallon barrel full of water, less stench that way.
I have never shot one in a trap don't plan to either.
