Search Forums | Classifieds (67) | Skins | Language
Deere 8295r overheating
Viper2bn
Posted 10/15/2020 17:13 (#8547457)
Subject: Deere 8295r overheating
Lottsburg VA
I have a 2017 8295r Deere, worked in the field until 9pm just fine, folded up and get on highway and doesn't make it a mile before egr temp high warning comes on and the tractor immediately overheats. Had to sit on highway for almost an hour to get it to cool down enough to move, got it off the road and cool down overnight, added about 1 gal of coolant still had an alarm but no codes for the alarm. Could not find a leak anywhere other than the overflow from overheating. Tractor only has 800 hours, fan turns fine but coolant does not circulate. Pulled thermostats today they were fine but replaced anyway, no loss of coolant, pressure tested fine for over 3 hours. Only working with one hand due to an injury 2 months ago, my guess is water pump impeller failed or gear failure on pump or engine, any ideas where to look, I will need to hire someone now need to cut soybeans and finish planting.
