![](http://www.newagtalk.com/mapdots/chebanse.jpg) Chebanse, IL..... | This 806 looks like it had an IH Fast hitch, but arms converted to 3pt. along with 3rd point add. Is this a FH to 3pt conversion?
Does it work OK as a 3 pt without the usual anti-sway bars that IH uses? It has sway block, somewhat similar to JD.
I know there were conversions, just asking if they work like they should? It has the load/depth control lever, just not sure if it all still works after conversions.
That LH ball attachment isn't broke, it's meant to pivot there until bolted solid. I've never seen that before either.
Thanks
(Rear 1 (full).jpg)
(Rear 2 (full).jpg)
(Rear 3 (full).jpg)
Attachments ----------------
Rear 1 (full).jpg (183KB - 427 downloads)
Rear 2 (full).jpg (183KB - 456 downloads)
Rear 3 (full).jpg (162KB - 444 downloads)
