Manheim PA | Need a way to run a hydraulic motor on a new to me hay merger. Need 2 set or outlets (one for up and down for the pick up and one for the belt). So got a ported filter cover to keep the oil in the charge circuit. Needed longer bolt and spacer to hold the filter in place since the new cover was about 2 inches deeper. Added break away coupler. Then for pressure teed in to the rockshalft supply. Then an electric solenoid valve and a manual flow control valve. The valves will fit under the rockshalft shield. Need to test before putting it on.
(IMG_20200501_092331985_HDR (full).jpg)
(IMG_20200501_092346384 (full).jpg)
(IMG_20200501_092354440 (full).jpg)
Attachments ---------------- IMG_20200501_092331985_HDR (full).jpg (156KB - 79 downloads) IMG_20200501_092346384 (full).jpg (155KB - 104 downloads) IMG_20200501_092354440 (full).jpg (157KB - 30 downloads)
