Montana | CH55 or MT7??
I like that my STX quad pulling a flexicoil air tank on LandLuvr tracks doesn’t compact my irrigated ground that I inline ripped in the fall. To level and warm ground in the spring I’m going to work ground with a home made coulter, phoenix harrow, coil packer. I need to pull this with a track tractor if I am not to pack the ripped ground. Will pull it at 7 to 9 mph so can keep the weight of it down. I am not going not be using this a lot of hour so would like to keep cost down. What are the differences between the older CH55 and the newer Mt series? If I go for the 55 what should I look out for in the used tractor? Not any of these tractors in my area so alittle help is needed. Thanks
