Search Forums | Classifieds (3) | Skins | Language
Tineweeders, which one?
Jrditchdigger
Posted 6/11/2019 21:30 (#7554111)
Subject: Tineweeders, which one?
Southern MN
Viewing a post below about Kovar tineweeders. Many use the Einbock in my area and it looks like the hatzenbichler are very similar with many tines close together. The Kovar is same concept but fewer tines spaced out more. I purchased a used Kovar and have used it once in corn and was impressed, although I need to rebuild the drag cart if I continue to use it next year to really make it work properly. Do the other brands plug quite easily? I can see where more tines should equal better weed kill but they really look like a dump rake. What is the difference in the brands and what are the pros and cons of each? At this point we would be using it in corn only. What do you like and why? Would like to be at 60’ is there quite an advantage to the mounted units over those mounted on a more traditional drag cart? At this point just trying to learn.
