| When you go to lower the main boom the motor pulls down like the oil is deadheading and the loader wont lower. It will raise fine and the bucket works alright. This has the self leveling function on it and suspect that is the culprit. With the switch off it acts this way and when you put self level on then the loader wont go up hardly at all and still wont lower. If you put it in float the loader will lower. Any thoughts on where to start on the contol valve would be appreciated. | |
