Search Forums | Classifieds (41) | Skins | Language
Baling Cornstalks wet fall
ajblair
Posted 11/11/2018 08:58 (#7098837)
Subject: Baling Cornstalks wet fall
Dayton, IA
I got just enough baled to squeak by, but could use 200 more. I don't have a moisture tester on the baler. Today high of 34, 70% humidity, light wind. No frost this morning. Do you just go bale whenever it works? Do moisture equilibrium charts for grain work for baling generally? Shows mid day air today will dry corn to 17% moisture. I got a lot of them really dry so I will save those for feed and to keep through the summer and use the last ones I bale for bedding right away. Not really an option to pick the right conditions because the year has not given us very good windows, but thought I would see if you guys with more experience have any rules of thumb.
Thanks,
A.J.
