![Click to enlarge](http://us.st12.yimg.com/us.st.yimg.com/I/yhst-5253399658814_2032_11619074)
LED Tire Alert Pressure Indicator- Save lives while putting $$ back in your pocket
- When tire pressure drops 2.96 psi you lose 4 cents a gallon on gas. (based on fuel efficiency of 20mpg and gas cost of $2.00)
- The VECSAFE Valve Cap is self-calibrating. When the cap is mounted on the valve stem the first time, it will memorize that tire pressure.
- The VECSAFE Valve Cap can be calibrated to any tire pressure between 20 and 120 psi
- The VECSAFE Valve Cap can be set to recognize a drop in pressure as little as 8 psi
- It can be checked for functionality and battery condition by simply unscrewing the cap. If it is in working condition, it will immediately start blinking.
- After 2 to 3 years of standby time, the VECSAFE Valve Cap can still blink about up to 3 weeks
- Heavy Duty brass chrome plated, Size 1" X 1/2", Weight 0.3 OZ
- Price is per individual LED Tire Alert
1234 $7.24![pad](http://us.st1.yimg.com/store1.yimg.com/Img/trans_1x1.gif)
