66524 | What is your experience with the old style hyd. ends popping out . Seems i have all ways had problems with them. This particular 4020 has had the valves you plug into rebuilt by a JD dealer.The ends or tips on the hoses seem to be in good shape and all the balls are in the female coupler on the tractor.I have set the flow to the low or turtle position and relieved the pressure on the hoses. Some times they connect and stay connected and other times not.Are they basically poor design or am I missing something.Thanks in advance for your input.I am sure some of you have had the same problem.Thanks again. | |
