SCMN | I had been asking on here months back about getting a BullPull style hitch for a grain cart with a round weigh bar on the tongue. I did locate one that was previously used by Unverferth, made by Scale Tech I believe. They had stopped using these and I can see why, they aren't heavy enough and would not allow proper oscillation.
https://talk.newagtalk.com/forums/thread-view.asp?tid=710983&posts=3#M6052734
What I eventually came up with was an adapter made by J&M to adapt the BullPull hitch as posted here:
https://talk.newagtalk.com/forums/thread-view.asp?tid=574653&DisplayType=flat&setCookie=1
The adapter was about $350 and the hitch was about $400. I had to grind a little bit off the back side of the adapter to make it fit my weigh bar, maybe 1/8". It makes the hitch about 6" longer. I have about 14" of PTO shaft overlap when straight which I am told will be ok even though the manufacturer calls for 16", I guess we will find out. Just wanted to post this for others to see.
(IMG_1025[1].JPG)
(IMG_1024[1].JPG)
Attachments ---------------- IMG_1025[1].JPG (131KB - 219 downloads) IMG_1024[1].JPG (121KB - 224 downloads)
