Statesville, NC | After a day and a half of figuring, looking at parts stores, fabricating and assembling, my Spra Coupe 3430 finally has good brakes on the left side. The right side will be a very easy fix now that I've got the bracket partially made. The local parts store had a '98 Ford Taurus rear caliper, with bracket. It has a provision for a parking brake cable, but that will be a project for another day. I've got used to parking on level. The main part of the adaptor bracket is 1/2 x 2 flat bar. I removed the guide pins for the original caliper, and drilled out the threads of the rear hole. I used the hole where the park brake spring anchor was for the front mounting bolt. I made a couple spacers, one of 3/4 flat iron for the rear, and machined a spacer 1 5/16 thick for the front. The calipers are turned with the piston on the outside, so I used a right caliper on the left side. The Cardone number for the right caliper (I used on the left side) is 18-B4536.
The brakes take a little more pedal pressure than the original, because they are smaller and have one piston. I think this is probably better for reliability, because the master cylinder is so small anyway. They release very well, and that's the problem with the original brakes. The Taurus rotor is about a half inch thick, so I'm going to watch the pads closely and not wear them too much. If I replace the pads, I may use the metal plate off one of the old ones for a spacer on the inside pad as a shim. I haven't been in the field yet, but I think it will be a 100% improvement over the original.
Edited by Trent2520 6/6/2017 14:19
(SpraCoupe brakes 001 (Small).JPG)
(SpraCoupe brakes 002 (Small).JPG)
(SpraCoupe brakes 004 (Small).JPG)
(SpraCoupe brakes 005 (Small).JPG)
(SpraCoupe brakes 006 (Small).JPG)
(SpraCoupe brakes 008 (Small).JPG)
(SpraCoupe brakes 009 (Small).JPG)
(SpraCoupe brakes 010 (Small).JPG)
(SpraCoupe brakes 011 (Small).JPG)
(SpraCoupe brakes 013 (Small).JPG)
Attachments ---------------- SpraCoupe brakes 001 (Small).JPG (41KB - 645 downloads) SpraCoupe brakes 002 (Small).JPG (38KB - 649 downloads) SpraCoupe brakes 004 (Small).JPG (42KB - 637 downloads) SpraCoupe brakes 005 (Small).JPG (35KB - 636 downloads) SpraCoupe brakes 006 (Small).JPG (44KB - 644 downloads) SpraCoupe brakes 008 (Small).JPG (48KB - 644 downloads) SpraCoupe brakes 009 (Small).JPG (63KB - 637 downloads) SpraCoupe brakes 010 (Small).JPG (73KB - 683 downloads) SpraCoupe brakes 011 (Small).JPG (77KB - 682 downloads) SpraCoupe brakes 013 (Small).JPG (68KB - 608 downloads)
