What are these pintle type implement hitches called ?
Posted 5/4/2017 09:32 (#5999894)
Subject: What are these pintle type implement hitches called ?
Cast implement tongue hitch designed for use with hammer strap hitch on a tractor.
I see you can get them with a bearing set up called a Bull Pull through Terog
http://blackaceparts.com/hitches.php
Also see non bearing types through CTD hitches.
http://www.thectdgroup.com/hitches.html
Wondering if the mounting bolt hole dimensions on the implement end are standard size /spacing or are different based on the category number ?
Also wondering if there are other sources other than JD that wants 180.76 for this piece. IDK maybe that is in the ballpark any ideas on what the CTD or Terog's typically cost ?
Image courtesy of CTD for reference purposes.
(pintle.JPG)
Attachments pintle.JPG (25KB - 337 downloads)
