Posted 2/18/2017 06:19 (#5847279) Subject: Adding water to in floor heat system
How often do others have to top off the liquid in your in floor heat system? It only takes a quart or two, to bring the pressure up to 12-15 psi., which is the recommended pressure. I usually have to do this 3 times per season. For those of you that are thinking about installing a new system, put a hydrant or a wall tap in the area near your heat system. Thanks.
