Search Forums | Classifieds (121) | Skins | Language
HP Needed for Pull-Type Sprayer, 8-Ton Spreader
The_Owl
Posted 9/5/2006 22:23 (#41655)
Subject: HP Needed for Pull-Type Sprayer, 8-Ton Spreader
Watford City, ND
I'm looking at a 7420 JD (120 PTO) for a new hay tractor. It comes auto-trac ready so what I'm looking at is using it for spraying, spreading urea, and haying. What HP requirements are needed for pulling an 850 - 1500 gallon pull-type sprayer? I figure the entire weight for both a loaded sprayer and fert spreader is around 18,000 lbs. Would this work? Anyone using this type of setup? Thanks guys...I'm new here, but after reading some of the post looks like this might be a good spot to get some agricultural wisdom. LATER!!
