AgTalk Home | ||
Repair nut for stripped axle spindle threads Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Detroit |
Crawfordsville, Arkansas | What are they called and where can I buy them? I've searched every term I can think of and come up empty handed. I had some years ago. No idea where they came from but they are a 2 part nut. Threaded on the inside to go on a axle spindle then the outer part is threaded also along with it being slotted. The outer nut clamps down on the slotted part and holds it tight to the bad threads. Any idea what the technical term of these is? I can't find a single picture of one. My supply ran out years ago and I need one today. | ||
Lone Wolf Picker |
Black Hawk County, IA | Try "Thread Restorer". A lot of older mechanics have a set of thread files too. They work great on spindles. J | ||
hd6gtom |
What do you need it for? Most antique tractor sites have them, Steiners have them in their catalogue, All States AG has them. | |||
Detroit |
Crawfordsville, Arkansas | hd6gtom - 10/5/2016 14:26 What do you need it for? Most antique tractor sites have them, Steiners have them in their catalogue, All States AG has them. 496 CIH disk wing wheel. | ||
Survivor |
Moreauville LA | Universal lock nut | ||
gene_champ |
NC Iowa | Please post back if you find one, and where. I just had a machine shop repair spindle threads with a thread restorer die. Hope there is enough thread now to tighten against bearing if i leave off the washer. Your way sounds better. | ||
dgpeak |
Is this what you are talking about? I haven't purchased any in years. I have this one. Must be 30+ years old. (thumbnail_IMG_0668.jpg) (thumbnail_IMG_0669.jpg) (thumbnail_IMG_0670.jpg) (thumbnail_IMG_0672.jpg) Attachments ---------------- thumbnail_IMG_0668.jpg (65KB - 195 downloads) thumbnail_IMG_0669.jpg (60KB - 194 downloads) thumbnail_IMG_0670.jpg (23KB - 165 downloads) thumbnail_IMG_0672.jpg (46KB - 171 downloads) | |||
dmax2001 |
Lawton MI | Can't remember where I saw them, but recently came across set of dies that are hinged. You open them, clamp on to good threads, lock, then turn into bad threads to chase them. Looks like a great idea. Maybe try googling. Edited by dmax2001 10/6/2016 16:49 | ||
telcofarm |
Yates , MO (north central) | Found this pinch nut. http://www.speedwaymotors.com/Stallard-Micro-Sprint-1-Inch-Spindle-... (IMG_1745.JPG) Attachments ---------------- IMG_1745.JPG (31KB - 182 downloads) | ||
Plow79 |
Chilliwack BC | X2 on thread restoring files. Used them on spindle threads before and they worked good. | ||
Detroit |
Crawfordsville, Arkansas | dgpeak - 10/5/2016 16:35 Is this what you are talking about? I haven't purchased any in years. I have this one. Must be 30+ years old. Bingo. Went to my local parts store and he called a few places. One guy said they were called a "swagger" nut. This is the brand he was talking about. Of course he didn't have any and said he couldn't get them anymore. Tractor Supply shows to have some. I'll run by there in the morning and snoop around some. Both the local parts store and John Deere said they have guys come in all the time asking for them but no one knew where to find them nowadays. | ||
Thud |
Near-north Ontario, French River | Depending on how bad the spindle is chewed up, we've had luck with a thread chaser. https://www.otctools.com/sites/default/files/styles/vt_commerce_imag... . | ||
Detroit |
Crawfordsville, Arkansas | Thud - 10/5/2016 18:27 Depending on how bad the spindle is chewed up, we've had luck with a thread chaser. https://www.otctools.com/sites/default/files/styles/vt_commerce_imag... . I've got one of those along with a few thread files but they aren't gonna help me with this axle. Threads are all but gone. I've used these Schwaiger nuts before on an axle with less threads than this one with good results. Just need to find one. | ||
ekeller2 |
So. IL | Otc 7402, you can look that up, it's the thread restorer we use for axles, works great but just don't go to deep with it. (image.jpeg) Attachments ---------------- (0KB - 205 downloads) image.jpeg (19KB - 148 downloads) | ||
dgpeak |
what size do you need? I can check mine out tomorrow. wouldn't bother me to part with it if you can't locate one. | |||
reedfarmer |
Eastern Arkansas | I have often wondered this too. You used to find them at every parts store and they worked great, then overnight they just disappeared. We always called them Schwag nuts. A john Deere 630 disk has a spindle that is welded to the frame and is a nighhtmare if you strip the spindle and cannot find these. Im pretty sure half the spindle nuts on mine are this style of nut. This rekindled my interest and it looks like after some searching the generic name for them is a "clamp lock nut" | ||
Detroit |
Crawfordsville, Arkansas | 3/4" | ||
dgpeak |
look up Steiner tractor, also on Amazon,. called a wheel clamp nut. | |||
Detroit |
Crawfordsville, Arkansas | reedfarmer - 10/5/2016 19:58 I have often wondered this too. You used to find them at every parts store and they worked great, then overnight they just disappeared. We always called them Schwag nuts. A john Deere 630 disk has a spindle that is welded to the frame and is a nighhtmare if you strip the spindle and cannot find these. Im pretty sure half the spindle nuts on mine are this style of nut. This rekindled my interest and it looks like after some searching the generic name for them is a "clamp lock nut" I used my last ones on a Fair Oaks roller. Same deal, welded spindle and too much work to replace when one of these will get you back running in no time. Tisco has them but there's no stores close by who buy from them anymore. SMA and Temco don't have any. Fastenal acted like they had never heard of them. I got a lot of blank stares when I asked for these in the past. I'll check with Tractor Supply in the morning and see if they have any. I'll post if I find any. | ||
Fat Man |
gibisonville ohio | tisco parts have several sizes | ||
gene_champ |
NC Iowa | http://extras.tiscoparts.com/locator.aspx | ||
dgpeak |
Sorry, I looked this morning. Mine is 1". | |||
hillfarmer |
Web site for Steiner http://www.steinertractor.com/ | |||
hillfarmer |
another try http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=nboard&th=4... http://www.valu-bilt.com/cgi-bin/sgin0101.exe?T1=A+568972&UREQB=2&U... did not bring up the threader restorer | |||
gene_champ |
NC Iowa | dgpeak - 10/6/2016 07:36 Sorry, I looked this morning. Mine is 1". i may need a 1" email me. | ||
Rawleigh |
White Stone, Virginia | I hope this helps. https://www.tractorpartsasap.com/SearchResults.asp?Search=wheel+clam... | ||
hillfarmer |
WE have a person with success !!!! | |||
(Delete cookies) | |
