Prairie Home MO | Both on here and also locally Authority Max seems to be doing a pretty good job on waterhemp. I believe it is both Authority and Classic. Question is about how much good is the classic doing in the mix? Or is the control coming from the higher rate of Authority in the mix? Or is it the combination of the two? We use some Fierice XLT and so far have gotten along, but scares me some with ph, splash on small plants and tank clean out. If you could get by without the Classic in Authority Max and still get the waterhemp control, that would be a plus. Thanks. | |
