South Central Kansas, Harper County | Planted Milo a few weeks ago, came up fine with good moisture, but turned dry the past 10 days. Used Verdict as a Pre, but have quite a few pigweed escapes in certain areas of the field. Field bordering the milo, directly to the south is corn just starting to tassel. Which would be a good choice for this milo, since the corn is so close? Ive used Huskie before, at later stages and it worked very well. Also have used 2-4-D or Dicamba, and have read Ally could be utilized also. 2-4-D might be cheapest option, but dont think the corn would like that very well? Will probably add a little atrazine for good measure along with one of the above. Any suggestions?
thanks,
Jim |
