NY | i am doing some research on closing wheels. planter is used only for soybeans. I plant No-till and Conventional. the planter has rubber closing wheels, they are worn out and need to be replaced. soil is typical NY with Sandy loam and Heavy clay type ground sometimes in the same field. Should i stick with rubber ones? or go with spiked or Cast? To many options. Thanks |
