Eastern Ontario | I have a AT3000 with a centrifugal pump hydraulic driven, with a teejet 844 controller.
And the controller have difficulty to maintain the right pressure, it vary from 20 to 50 PSI at every 2-3 second, after a while it stabilize the right pressure. But I maintain my speed and throttle and application rate and it start again going up and down with the pressure. I tried to adjust the regulation adjustment speed in the setting and it help to stabilize faster, but why he does it when the speed don't change?
is it because the flow is too slow to be in throttling mode?
It's my first fertilizer applicator i run, i'm not completely use to it! | |
