Search Forums | Classifieds (40) | Skins | Language
John Deere 2600 display issues
gpm
Posted 5/27/2016 04:38 (#5322762)
Subject: John Deere 2600 display issues
NW Ohio
I am using a GS2 2600 display for autotrac with a ATU200 and starfire ITC receiver. I was planting with no problems. I came out the next morning, and it won't work. A box showed up on the screen and says: "setup incomplete. go to menu/greenstar to complete or cancel active window". When I go to the GS2 screen, it won't allow me the normal set-up pages. I can't get into the autotrac stuff or to set up a/b line. It won't let me in the documentation or diagnostics sections either. At first it would not let me change the implement type info or tractor. I removed the card, replaced it, then I could change the implement and tractor stuff. Any ideas? I can't find it in the operator's manual. I did not see any active codes on the display. I powered it off and on several times with the same result each time. TIA
