Search Forums | Classifieds (76) | Skins | Language
JD 4830 Fault Code - ECU 636.10
BAB84
Posted 5/21/2016 21:26 (#5313750)
Subject: JD 4830 Fault Code - ECU 636.10
Spraying today and this code came on. I looked it up and it says camshaft signal rate of change abnormal. Shut the sprayer down for a few minutes then started again and I was able to clear the code and the sprayer ran fine! Anyone else have this issue? Think we need to replace the sensor and where is it located? Thanks for your input!
Edited by BAB84 5/21/2016 21:26
