| How many gallons per acre should I be spraying with Headline and Warrior on soybeans. Usually ran 10gal/acre with roundup. Should I go to 15 or 20.
Also, what kind of nozzles should I be using.
Edited by farnerbob 7/13/2008 13:55
Yadkin County North Carolina | Check this website rs.ag.us/ this Soysoap really works |
Yadkin County North Carolina | correction rs-ag.us/ |
Lee Co | BASF rep told me by ground they want a MINIMUM of 15 gallon water to 20 gallon they would like 3+ gallons by air but none of the planes around here will use over 2. said using XR tips gives you good coverage also. |
| How much would a person use on soybeans and tobacco/TIA |
SWOH | we use 15 gpa and xr nozzles |
| Like the others said, 15 GPA minimum. Do not use AI nozzles. |
