Search Forums | Classifieds (40) | Skins | Language
JD 2600 monitor freezing up?
seedcleaner
Posted 4/7/2015 22:49 (#4503270)
Subject: JD 2600 monitor freezing up?
Mid-Missouri
I have a 2600 monitor doing autosteer and swath control on a 4710 sprayer. Many times during the day, the screen will freeze. Fortunately, it still maintains controlling the machine as it should (for the most part), but the screen freezing needs to be fixed. It will do it turning around, middle of an A-B pass, etc... It usually catches up after a minute or two, sometimes falsely showing double coverage in the field in places I applied while it was locked up. The monitor has a 2 gb card and is 1/4 full.
Do you think the card needs cleaned? If so, and I took it to a neighbor with Apex, what files should be left alone to keep my boundaries, field names, and A-B lines?
Thanks.
