is it ok to use #1 diesel, cont...
rustndust
Posted 11/21/2014 04:02 (#4191296)
Subject: is it ok to use #1 diesel, cont...
I've been fortunate this winter "so far"...to not have any gelling problems with the fuel...still harvesting so plenty of engines being used yet.
No heated shops to park them in...so I added an early treatment with "Howes"....probably way over treated on a recommended per gallon basis.
I had most of the farm supply tank, tractors, combine, and vehicle tanks mostly filled with #2 when the forecast called for much lower temps...unable to burn it all out before adding #1...so they got the "howes" treatment right away.
After they got used more..there was room for #1 to dilute the #2.
Point of all this is that I got the "howes" into the tanks before the fuel temperature got real cold.
I was told that if you do it before the fuel temp in the tanks goes under 55 degrees f....it will mix better and not stratify out while sitting in a cold tank.
Just wondering if this is true in anybody else's experience?
I've had enough trouble in the past to last me a lifetime....especially the year we were using biodiesel when it got cold.
Also, this link from Iafarmerken was most interesting, thanks Ken. http://fleetowner.com/site-files/fleetowner.com/files/uploads/2012/09/Fleet%20Owner%20rebutal%20article%209-1-12.pdf
