| I am fed up with this thing. I have tried variable rates of foam, different types of foam. I even bought the $45 a piece 'smucks' as it says on the ticket from the JD dealer. I think I am getting too much water or not enough air. What normally wears out on these things or what would you look at first? The reason I think it is letting too much water by is because when not in use it constantly drips overnight and I have to refill the foam tank every fill up (40 acres). TIA | |
