SE IL | We are running 28.6 software. We Didn't have a problem with wheat but are having a terrible time getting the combine calibrated with corn. Moisture is fine but the yield will be 3% off then 22% off. We are using the Wizard. Each load is roughly 4000 pounds.
A strange thing is happening when we do the low flow, medium flow etc. For example, when calibrated with low flow, we are going along fine and we accidentally push the combine a little too fast where it jumps up into the medium flow category. The pounds then resets to zero and starts counting. I assume it is counting medium flow. When we slow back down into low flow, our original poundage comes back. However, is that medium flow that was counted, count in the total poundage?
Also, do you need to calibrate each crop? We do wheat, corn, beans.
Edited by chedv 9/19/2014 21:50
