Search Forums | Classifieds (37) | Skins | Language
Cutting a Hole in a Tire Tank
Augustus
Posted 9/18/2014 18:47 (#4081171)
Subject: Cutting a Hole in a Tire Tank
Lonesome Dove, TX
I'm wanting to 'tie' 3 tire tanks together so when one fills it over flows into the other and so on. I would like to cut a 2 inch hole in the side of the tanks and use PVC pipe to run between the tanks. I'm hopeing to use a hole saw but cannot find any deep enough. The tank is about 6 inches thick and has steel in it also, any ideas. Thanks
