Rogator hyd. problem
pistons
Posted 5/9/2014 19:50 (#3861315)
Subject: Rogator hyd. problem
2005 Rogator 1064. It have very low drive pressure in forward position of the hydro handle, but normal pressure when going in reverse. All four speed ranges act the same. Found the two hot oil shuttles had come apart inside the drive block. Screwed them back together and re installed. No change. I was going to swap the two around and found that the O-Rings on the spools were cracked and brittle. Waiting an parts. Do you think this could be the problem? The machine had been working just fine just before it lost pressure in forward. It does move but not with authority.
