Motor Return on 30-40-50-55 ETC...
1586
Posted 4/30/2014 21:10 (#3847067)
Subject: Motor Return on 30-40-50-55 ETC...
Sprayer has a motor return end and it obviously won't work with standard couplers. Dealer had set me up with a return that goes into the rear plug on the trans. housing which later I learned here doesn't cool the oil. It's only a sprayer pump but is too much heat or what is the proper part numbers to use for the return setup.
