Tip of the Thumb of Michigan | If not, it is because your master is in the rearward position. Chrome out the back is up. Chrome out the front is down. Does it have spacers between the front nut and cylinder housing, held on with hose clamps? If so you need to get those off and try raising the planter and hold the lever and it should recharge the whole system.
