Search Forums | Classifieds (108) | Skins | Language
Need a little what to use on soybeans Pre&Post advice.
Worthmore
Posted 4/16/2014 09:14 (#3819508)
Subject: Need a little what to use on soybeans Pre&Post advice.
Live in Forsyth, Missouri Farm in N, MO
I have only used Roundup &24D pre for the past few years and Just Roundup Post and has worked Very well till last year; The only problem then was waterhemp! This year I want to switch things up a bit without breaking the bank! What would you suggest as a Pre for residual and as a Post with residual. I still plan on using rup and 24d for burndown. I will be using RR2 Soybeans all No-till on 15"rows ...about 25 acres into corn stubble and 75 acres into bean stubble. The other thing I would like to be able to do if possible is use the nozzles I have without a lot of switching and setup. Currently setup to put on 15 GPA if that makes a difference. Thanks!
