Central Ontario | I picked up a couple switches and the instructions say to install the switch in the ground cable.I have a machine with a factory installed switch and that is the way it is.The question is I was thinking of running a wire with a 2 amp fuse for the radio/clock memory but there is only one ground on the radio.Why not install the disconnect in the positive cable then the small fuse would only power the orange radio wire not the complete radio. | |
