Sw Mo | Been looking and reading over lots of pasts posts on here and wanted some opinions. Looking at getting first sprayer for the farm so have no previous experience with all this.
When using a venturi on an eductor setup for 3" to pull chemical from totes will I have enough time to get dry ams, roundup from tote, and maybe a smaller quantity chemical in an 800 gallon load before it fills with water?
Or would be better to use 2" on everything after the pump even if sprayer is 3" fill capable?
Does using the venturi to suck chem from totes work ok?
Would plan on using a flow meter of some sorts to measure chemical. Everything would be pretty close together because plan on building the tender setup on a 24' gooseneck.
Really like this setup: only change might be using a handler 3 instead of 2 smaller cones.
http://talk.newagtalk.com/forums/thread-view.asp?tid=98867&posts=12...
Edited by Campbell Farms 1/26/2014 20:47
