| Pro 700 will not generate curve swaths after it has already generated several across the field. The tractor follows the guidance lines fine when engaged but randomly the swaths quit generating. For example, you make a curve swath and get to swath number 20, swath number 21 and following do not show on display nor can they be engaged on. This is only when doing a curve swath pattern.
Magnum 315
Pro 700 software version 28
NAV II version 3.88
372 version 3.011.4
Anyone else seen this and fixed it? | |
