EZ Steer A-B Line Issue
burky8520
Posted 11/20/2013 01:29 (#3456162)
Subject: EZ Steer A-B Line Issue
NW Ohio
Running a EZ Guide 500 on WAAS, with an EZ Steer. Started having issues in our 4WD tractor this fall, the unit will hold an AB line perfect, but when I turn on the ends and go back to where I want the tractor to be, it shows I am 3 foot or so off my AB line. I measured my implement and plugged in what width I wanted, I also have re-set the AB line with different widths more and less than what I measured to see if that would correct it or get my deficit closer, all with no success. What I end up doing is a AB line shift after i get turned around, and I am good until I turn again. Any suggestions?
Thanks
