South Africa | I have a couple of clients with Integra's doing hydraulic seed control and seed tube monitoring. From last week we have seen that the monitor is doing strange things. While planting, it will show that the population is very low, but the actual rate that is planted is correct.
If we power down the display and start it back up, it will run fine for a while and then start doing it again. We checked the actual spacing on the ground and its fine. Sometimes it will also show a high population for a while and then agian a low population.
Integra is on v4.5, all modules up to date with newest firmware and we are using dickey john sensors. Has anyone seethis happen? | |
