Real advantage to having boundaries done with RTK?
4WD
Posted 11/17/2013 18:39 (#3450590)
Subject: Real advantage to having boundaries done with RTK?
Between Omaha and Des Moines, 7 miles South of I80
New to GPS, but I have seen an ad that states they(private company) will create boundaries using RTK, on your fields.
I assume that this would help, year after year, because hopefully your boundaries would stay roughly within an 1-2"(RTK), where as, if I do all mine, with WAAS, then I may be having some drift issues, each year AND/OR each time, I use my GPS WAAS signal. This would affect outer field boundaries, "regions", waterways, terraces, ditches.
Is this a correct understanding?
Am I making too much of a big deal about this?
Note: I was told the COOP only uses WAAS, and I see their NH3 outer knife, in the grass, along the fenceline(not where is should be), so I assume, this is the "WAAS drift".
The "inside contours" looked like a perfect curve, pass to pass.(As seen on a hillside, from the road)
