Search Forums | Classifieds (127) | Skins | Language
Trimble 262 Port C
BigCAT79
Posted 11/15/2013 06:44 (#3445620)
Subject: Trimble 262 Port C
I need educated on Port C for a trimble 262 receiver. I'm going to wire up a external radio to run RTK. Will be used for autosteer with a pro 600 then moved over to a tile plow as well with a different controller. If I used port C to get the RTK correction into the receiver the Pro600/700 will not auto config that port and reset my settings correct??
If I looked at the pin out of port be correctly I need to use the following pins in port B to use port C: 5-GD/6-TX/8-RX.
TIA
