Idaho | I have acquired two what I believe are Envizio Pro II displays and some harnesses however I am really not sure what I have. The nearest really good Raven dealer is about 100 miles from me. I was wondering if Raven has a site where you can look up part numbers to determind what one has? Or maybe someone here can tell me what I have.
First display has this number on it 063-0172-865B Rev. B and came with 115-0171-746 harness, 063-0172-651 GPS antenna, and 115-171-787 antenna cable
Second display 063-0173-258 Rev. C and came with the following cables and accessories. 115-0171-326 harness ? 115-0172-001 harness main 115-4001-085 harness ? 115-0159-822 harness RS-232 115-1001-003 harness accuboom 115-171-787 antenna cable 063-0172-651 GPS antenna (2) 063-0172-369 terminators 106-3017-2316 accuboom control node
I would like to install this equipment into a 3388, 3788, 1470 combine and a 215 Spray Coupe. I plan on starting over in the Coupe with all new valves and right now it does not have any flow control so that would be added too. I was told in the past I would need a switch pro 4400 to control the flow and valves but was never told anything about a control node and can terminators. I am not sure what they do, can they take the play of the switch pro or are they in addition too? In time I will would like to add a steering system and know for the Coupe it would have to be a smartsteer system. For the tractors and combine not sure if I could tie into the hydrualics or just go with the smartsteer on them too.
I would assume the sprayer will have the most wiring in it but not sure what harness's etc. that I really do need. The tractors and combine would be a more basic harness? I also have two TM-1 tilt modules that I will use until such time as I do get the steering part of the system. I plan on getting with the dealer in the next few days but would like to have some information before hand. I have been using the older Envizio Plus for a couple of years but only for guidance with the light bar. The displays on them are getting dim so thought it would be a good time to upgrade. The local fertilizer plant is using raven flow valves on their NH3 machines so decided to stay with raven products. Plans are to have the wiring in each machine and just switch the antenna and display as needed. Can anyone help me out with this project? |
