| Currently applying nh3 and have a couple questions for you experienced raven guys. First off the speed on the raven was reading roughly 2 mph higher than I was actually travelling. First couple tanks went on heavy but it's better heavy than light. Now that this speed is corrected im guessing that will help solve that problem. The other concern is the acre counter...it reads higher on the raven by quite a bit than it really should. The correct width is entered in the monitor and has been from the start so I'm not sure why it's out by so much. Any pointers would be greatly appreciated. Thanks | |
