Morris, IL | Got some rain and some time to look over some of the yield data from what we have combined. I setup regions in the planter tractor, sidedress NH3 tractor, and neighbors Hagie when I topdressing more N so i could find those passes in SMS to overlay on top of harvest and get plot data. Works great so far, combine doesn't even know what is going on, doesn't stop or anything. But problem i'm having is it is grouping passes together for some reason when using the select a pass method. For the entire field i can select a pass and it will work fine but in these areas it will sometimes group two passes of same legend together. Sometimes two or three pass of different legends, or even a half pass here or their. Wondering if anyone has seen this and knows what it is? Kind of makes getting good results tricky at times. Thanks in advance guys, i'll try and take some pictures of this to better explain. | |
