![](http://over30clan.com/uploads/imgs/pre_1436738150__wileecoyote.jpg)
| I'm in the process of creating "managment zones" for soil sampling and VR. I created boundaries with FW Mobile on a tablet, and read those boundaries into my SMS software. I would drive around a topographical feature which you'll see in the screen capture, but there are areas that are void of a spatial objects(a few examples circled in red). I want those to be managment zones as well, I thought I could use a type of "fill" feature(like top right red area) to create a spatial opject that would use the boundaries of the other objects instead of having to drive around EVERY zone seperately. I've done it by "adding polygon" and using snap vertex feature to follow the other boundaries, but its kind of time consuming when you have dozens of points on curves and complex shapes to click on every vertex. Is there some good way to use the other boundaries to create a new spatial object, or am going to have to use the "add polygon" to do it?
Also, why do some objects shaded green and some gray?
Edited by 00rooster 10/29/2013 13:49
(Capture.jpg)
Attachments ----------------
