Search Forums | Classifieds (133) | Skins | Language
T8.360 Wheel Angle Sensor problem with Paradyme, Torn?
TS79
Posted 10/28/2013 21:46 (#3409903)
Subject: T8.360 Wheel Angle Sensor problem with Paradyme, Torn?
NE Iowa
Have a customer with a 2013 T8.360 put a Paradyme steering kit on it utilizing the factory WAS. The wheel angle sensor was intermittently working, it would indicate a normal amount of 'counts' as you turned from left to right and then it would stop working showing 0 then once you turned the wheel it would jump to 65,000..
Put a new factory wheel angle sensor on and have the same problem, leaning towards swapping cables next. The wheel angle sensor has a short lead off it than ties into another harness but I'm not sure where it goes from there. Anyone have a wire diagram available? TIA
