Lewisburg, PA | Older of moisture sensor. Auger burnt out customer want new prox switch and auger. Can't get new auger to run. I adjusted prox with the screw and it works with the push button on the cover but I hold something up in front of prox switch and nothing....
Even got new moisture module.... What's the name of little black junction box that auger and switch go into? Is this bad??
Tech support told me to turn the little crew on the prox switch till the auger turns.. It never did but it made the test switch work now, but like I said above when I hold something infront of the prox switch nothing...
Edited by panotiller 10/27/2013 17:45
