NC, IA 50653 | OK I've got a strip till machine that is 18 rows and I can also fold the wings to do 12 rows. I've got section shutoffs for the liquid fertilizer. It has 9 section so it shuts off every two rows. Ive got two different implements set up in the Insight so I can switch back and forth. My problem is I'm not sure how to set up the 12 rows. I need to only use the middle sections... how do I do that to put it simply? It won't let me select which valves I want to use. Steering is done with a FMX so that is not an issue. | |
