| I recently put an atu 100 in a combine and it wouldnt work. by this i mean it seemed to not have enough power to move the wheel at all. I thought the steering might be to tight and it didnt have enough power to turn the shaft, so i took it off and held it and still wouldnt work. I figured the atu was going bad so i bought a 200 and Ive install it and it does the same thing whenever I go to the diagnostic screen on the display and try to turn the wheel with the buttons it just quivers and then says ' Invalid Controller Voltage'. Is this the common symptom of not enough voltage or is there another problem? From what I've seen from reading other threads they usually work for a while then kick out. Thats not the case here. which wire is it in the atu harness that you should hook directly to the battery? | |
