YM2000 Moisture Trouble. Sensor or wire?
mhalter
Posted 9/20/2013 12:40 (#3339074)
Subject: YM2000 Moisture Trouble. Sensor or wire?
Vincennes, IN
I have an Agleader YM2000 on a 7720 TII. I cannot get the moisture calibrated. I've never had any trouble with it until this fall. It is reading much too low and I am topped out on the offset (+15%) and it still shows around 14% in 20% corn. Do you think this is a sensor or wiring problem? This is an elevator mounted unit and the temperature is working which leads me to believe the wiring is okay? We did have a right side primary countershaft bearing failure last fall and the way the wire was run it rubbed through the rubber jacket on the wire. I taped it up and finished last fall with the monitor working fine, but?
