Missouri | Has anyone moved an Ag Leader CAN-based yield system from a 9x10 combine to a 9x60 combine and care to share their insights on it?
The new machine has had Ag Leader before (but previous owner stripped it back out), so some things, like the holes in the elevator for the EMU, are already there.
The flow sensor has been sent to Ag Leader to be rebuilt in a new mount to fit the new machine.
The rest of the plan is to order the necessary hardware to complete the flow sensor installation, order parts as necessary to move/adapt the EMU, and modify cabling as necessary to reuse as much of the existing cabling. I have the capability and materials necessary to fabricate cables using weatherpack and Deutsch terminals, so where possible, the 9x10 kit cables will get extended as necessary rather than ordering replacement.
The 9x10 EMU has a different hole and bolt pattern than the 9x60 EMU. This 9560 machine already has holes to fit the 9x60 EMU, so simply cutting the elevator to match the EMU from the 9410 is not an option. Does anyone have an idea that does not require total EMU replacement? | |
