WA, Australia | Hi, I am loading a data card for a customer with his boundary's and AB lines from SMS into a PRO 700 all which has worked perfectly apart from-
Three fields with separate boundaries all use the same AB line I copied it in SMS and placed it in the management tree under the appropriate field.
but when I load the card into the display it only shows the AB line for the one paddock where it was originally copied from. I have tried it as different years as I thought this might be confusing the monitor. The AB line when viewed in SMS was created across the boundaries of two paddocks.
Does anyone have any ideas how to fix this?
thanks in advance | |
